·My buddy's supra was running between 10.0-10.5:1 air/fuel ratios on the dyno yesterday, which is a little ridiculous. I was wondering if there is any easy/inexpensive way to lean out the entire fuel curve a bit. What if we cut the signal wire from the stock MAP sensor and put a potentiometer in the middle? Would that allow us to trick the ECU into to thinking there's say 16 psi instead of 18? What about if we modified the signal from the MAF instead? Or would we have to modify both?
Obviously it's not going to be as good as using a fuel computer... but if we could get the a/f into the 11's at least that would be great.
-Paul
-Paul
