if you do keep us posted. what hp figures are do you think you will get with that setup? i wonder if that will be streetable?
1jz power
have u had your car dynoed with the t78
i was thinking about getting one but am a tad worried about lag and what sort of power it will get
daymWith the greddy t78 and 272 cams you can hit close to 1000hp at around 35psi. I see almost no lag. Mainly because I always keep the rpm above 4500.
Are you still on a 1JZ bottom end? What kind of power are you making with the 77, how is spool. I'm not so much worried about spool as I'm auto and I can just match a stall to be close, but would like an idea. I'm really contemplating doing the 2J block swap and a 76.I ran a HKS T51 ( Big MOFO) on stock cams and that fat bitch would not even spool in 1st gear............... it would however spool at 5000 in 2nd and check the fuck out.
Now I am on a 77mm precision and much happier.
and I will kiss the man ass that knocks out 1000hp on a 1jz with a t78 with out N2O
I hope your joking! A T78 will not get anywhere near 1000 hp no matter how much boost you try to get out of it.With the greddy t78 and 272 cams you can hit close to 1000hp at around 35psi. I see almost no lag. Mainly because I always keep the rpm above 4500.
Hmmm... Thats kinda what I was thinking. Then again, I dont have a T78I hope your joking! A T78 will not get anywhere near 1000 hp no matter how much boost you try to get out of it.
