I am having trouble with my new system. I have...
(2) Boston Pro 12.4 Subs in the hatch
(2) 6.5" Boston Pro Components in the front doors
(2) 5.25" Boston Pro Components in the rear
The 4 component sets are run off an a/d/s 6-channel amp and the subs are run off a 2-channel Rockford Fosgate. I have a crossover running wires to the amps. All this is run off a Sony 910 head unit.
I used to have this system in a 97 Camaro RS. I am now installing it in my 93 Supra TT. I made templates for the fronts and rears and mounted them in the stock locations. There is a good deal less room for these speakers than there was in the Camaro.
When I hook up the system without the subs there is quite a noticeable difference in quality between how the Camaro sounded and how the Supra sounds. The highs coming from the 4 component sets sounds great, however there is virtually no bass. In the Camaro (without the subs hooked up) just 2 of these components alone would make the car shake with bass. Now with all 4, there is very little bass. There is sound coming from all the speakers and tweeters but like I said, very little bass.
Can any of you install gurus think of any recommendations what might be keeping it from sounding like it did in the Camaro? Like I said, there was a little more room for each speaker but I dont think there would be enough to make as big of a difference as there is, and again I could rattle the car with just 2 of the components. I can post pics of the speakers installed if you think it may help you.
Please let me know if you have any advise.
Thanks in advance,
Jeff
P.S. The amps are the same and are tuned the same as
they were in the Camaro
Thanks in advance,
Jeff
