I will be staring my winter work on my 87. Here is the list of items I will be working on. If you have any suggestions on problems I should look for, help would be great. I have a Toyota Manual for the 87. Here is my list:
Remove rear cradle
Swap out diff for better one(in hand)
Install sway bars front and rear(in hand)
Rework spindles
Install poly bushings for cradle(in hand)
Transmission input seal replacement(in hand)
Dash swap(remove alarm)in hand)
Replace hatch gasket(in hand)
Replace side marker with new(need to buy)
Repair small rust spots
Get dash lights working(figured this out, cause is aftermarket radio)
Run amp wire(in hand)
Replace hatch struts(in hand)
This is a lot of work to be done buy end of April/May of 21. Pointers are welcome.
Remove rear cradle
Rework spindles
