1 - 19 of 19 Posts
RoastBeefCurtain Commando
Im racing this weekend and didnt even think about speedcut. Is there anyway to bypass it without running an SLD? Id like to save the $100 for this weekend if possible.
Ludicrous speed! GO!
What kind of racing? drag? oval? road course?
Moderator, l337 M0d3r4t0r
Yes, zenner diode (spelling) all my sard ecu does is cut the signal after 180 KPH and i throw a code but it's all good.
Does it really matter? I will be going over 120 I am sure. Thats the point.
But I will be drag racing.
Zazzn, any instructions on this zener diode hook up. So you can do that for boost cut and speed cut then? I saw this option for boost cut before, but I can hit 2 bar fine, so I should be good there
1JZ BLING
If you really need a quick quick fix just unhook your speedo cable from under the car and you wont have speed cut anymore.... you wont have a speedo reading either, but who cares about that.
ahhh I wasn't sure if unhooking the speedo would do it or not, but though it might.
Thats cheap and easy. lol. Ill try that I guess.
If you are dragging, the only thing you should be looking at is the roadway and the tach.
Just don't forget to reconnect it!
no it's the wire you don't need to unhook the mechanical speedo cable.
just the wire to the ecu.
Nocheez said:
Speed cut? I wasn't aware our cars had a limiter.
He has a 1jzgte, jap cars have a speed governor.
Not so boring anymore
cut the wire
Discussion Starter · #13 ·
i thought 7M's had speed cuts too?
anyway Im not gonna pull a pin from the ECU, Ill pull a connector on the tranny or the whole cable itself.
Oldie but a Goodie
Most definately not. At least not here in the good 'ol U S of A. I've been at 140+ on a number of occasions, and unless the speed cut is over 150, which would be stupid, then there isn't one.
ive take my 7m to 170 no speed cut :)
only speed cut the 7M has is the rev limiter...
1 - 19 of 19 Posts
