That's what I was worried about. I think the housings are too restrictive for how much air that thing needs to move. The GT4718 from Garrett is already over compressor'd, the only way to combat that being using their 1.39 T6 turbine housing. A .96, or worse yet a T4 .96 isn't going to move enough exhaust gas in my opinion.
LMAO, errol your comments are out of this world!If I was going to listen to anyones opinion about hot air, it would be this guy.
Were did you get your turbo from, and what is the hp rating on it.The man speaks the truth(Mr Conte). I have a 80mm turbo with a 83mm turbine with a .81 a/r t4 myself. Listen to him, if he says go with something else, go with something else.
What do you suggest, i run a 76gtq now.Then it is even more of a restriction than the T6 housing would be already with the small turbine wheel. I would suggest trying to get something else.
I got it from jose here http://forcedinductions.com/productsborgwarner.htmWere did you get your turbo from, and what is the hp rating on it.
