Has anyone ever really done some work to try and figure out why the supra brake pedal lacks so much feel?
I have one idea and a similar situation to back it up.
After I installed my trd strut bar I started getting a metalic squeak when the engine torqued, mainly at start up, sometimes under quick accel from a dead stop. Turns out there were two little metal prongs on top of the rubber damper thing that the throttle cable goes through, which connects to the bracket mounted on the block side of the intake manifold; which was touching the bottom of the strut bar and making the squeak when the motor torqued around any. When I took the bar off to check it out sure enough there were two little flat spots on the under side where the prongs had been touching.
Anyway, after I cut the prongs off and shaved some extra off of the top of the damper thing, the bar cleared it fine, the squeak went away, and.....the gas pedal suddenly had 10x more vibration in it. Apparently the contact between the metal prongs and the strut bar was dampnening alot of vibration/pedal feel, that would normaly make it all the way to your foot on the gas pedal.
I dont know much about barke systems, but my initial thought was that somewhere the vibration that would normaly make it all the way to your foot is being dampened, either by accident like with the trd strut bar, or was designed like that on purpose.
What do you think?
What do you think?
