1 - 8 of 8 Posts
Word.
Like it says in the title, I was wondering if anyone knows or has a complete list of all TRD parts made for the supra, both current and discontinued. I like to collect TRD supra parts and I know I am probably missing quite a few.
Dave
Curt in the elmhurst forum did a full list in a post. try to search
Newbie
1993 1998 JZA80 2JZ-GE, -GTE 17801-JA810 00642-17801-002 Air Filter Air Filter For replacement, standard type
1993 1998 JZA80 2JZ-GE, -GTE 51700-JA800 Body Part Wide Body Kit For 93 - 96 Model
1993 1998 JZA80 2JZ-GE, -GTE 51700-JA810 Body Part Wide Body Kit For 96 - 98 Model
1993 1998 JZA80 2JZ-GE, -GTE 53311-JA800 Body Part Hood This part is not included in Body Kit
1993 1998 JZA80 2JZ-GE, -GTE 76871-JA800 Body Part Wing, Type-S (Adjustable) This part is not included in Body Kit
1993 1998 JZA80 2JZ-GE, -GTE 76871-JA810 Body Part Wing, Type-R This part is not included in Body Kit
1993 1998 JZA80 2JZ-GE, -GTE 47031-JA800 Brake Hoses Brake Hose Set, Stainless Steel Braided Front & Rear ; For off-road or race only
1993 1998 JZA80 2JZ-GE, -GTE 43512-JX001 Brake Rotor Brake Rotor, front, right 5-Slitz, 323mm dia. for stock size brake caliper
1993 1998 JZA80 2JZ-GE, -GTE 43516-JX001 Brake Rotor Brake Rotor, front, left 5-Slitz, 323mm dia. for stock size brake caliper
1993 1998 JZA80 2JZ-GE, -GTE 04491-JA820 Brake Pads Brake Pads, front, for 16" wheel 9270S (New Type) for Street
1993 1998 JZA80 2JZ-GE, -GTE 04491-JA830 Brake Pads Brake Pads, front, for 17" wheel 9270S (New Type) for Street
1993 1998 JZA80 2JZ-GE, -GTE 04492-JA820 Brake Pads Brake Pads, rear, for 16" wheel 9270S (New Type) for Street
1993 1998 JZA80 2JZ-GE, -GTE 04492-JA830 Brake Pads Brake Pads, rear, for 17" wheel 9270S (New Type) for Street
1993 1998 JZA80 2JZ-GE, -GTE 48157-JA800 DISCONTINUED Bushings Insulator, Coil Spring Front
1993 1998 JZA80 2JZ-GE, -GTE 48257-JA800 Bushings Insulator, Coil Spring Rear
1993 1998 JZA80 2JZ-GE, -GTE 48632-JA800 Bushings Upper Arm Bushing Front
1993 1998 JZA80 2JZ-GE, -GTE 48654-JA800 Bushings Lower Arm Bushing, #1 Front
1993 1998 JZA80 2JZ-GE, -GTE 48655-JA800 Bushings Lower Arm Bushing, #2 Front
1993 1998 JZA80 2JZ-GE, -GTE 48680-JA800 Bushings Upper Support Bushing Front ; Non-TEMS
1993 1998 JZA80 2JZ-GE, -GTE 48725-JA800 Bushings Lower Arm Bushing, #1 Rear
1993 1998 JZA80 2JZ-GE, -GTE 48725-JA810 Bushings Shock Absorber Bushing Front
1993 1998 JZA80 2JZ-GE, -GTE 48750-JA800 DISCONTINUED Bushings Upper Support Bushing Rear ; Non-TEMS
1993 1998 JZA80 2JZ-GE, -GTE 48785-JA800 Bushings Strut Rod Bushing Rear
1993 1998 JZA80 2JZ-GE, -GTE 52205-JA800 Bushings Cushion, Body Mount Rear & Rh.
1993 1998 JZA80 2JZ-GE, -GTE 52206-JA800 Bushings Cushion, Body Mount Rear & Lh.
1993 1998 JZA80 2JZ-GE, -GTE 52271-JA800 Bushings Suspension Member Cushion Front
1993 1998 JZA80 2JZ-GE, -GTE 52273-JA800 Bushings Stopper, suspension Lower Member Rear
1993 1998 JZA80 2JZ-GTE 31210-JA800 Clutch Clutch Cover (for Turbo)
1993 1998 JZA80 2JZ-GE 31210-JA810 Clutch Clutch Cover (for Non-Turbo)
1993 1998 JZA80 2JZ-GTE 31250-JA800 Clutch Clutch Cover (for Turbo) Ferodo type
1993 1998 JZA80 2JZ-GE 31250-STB62 Clutch Clutch Disc (for Non-Turbo) Metal Facing ; For Race only (Not recommend for Street)
1993 1998 JZA80 2JZ-GE 31250-SW251 Clutch Clutch Disc (for Non-Turbo) Ferodo type
1993 1998 JZA80 2JZ-GTE 31000-JA800 Clutch Twin Plate Clutch Set (for Turbo Model) 2-discs, cover, center plate, flywheel (need new flywheel bolts separately)
1993 1998 JZA80 2JZ-GTE 90947-JA800 Clutch Hose Direct Clutch Hose Stainless Steel
1993 1995 JZA80 2JZ-GE, -GTE 12360-JA800 Engine Mount Engine Mount Front
1995 1998 JZA80 2JZ-GE, -GTE 12360-JA800 Engine Mount Engine Mount Front ; Require to change mount brackets (Ask Toyota parts #)
1993 1998 JZA80 2JZ-GTE 12371-JA800 Engine Mount Engine mount, rear For 6 speeds M/T only
1993 1998 JZA80 2JZ-GE, -GTE 17400-JA810 Exhaust System Exhaust Muffler
1993 1998 JZA80 2JZ-GTE 04413-JA800 LSD LSD Clutch Plate set For 41301-JA800 : For replacement
1993 1998 JZA80 2JZ-GE 40101-TA401 LSD Shim, initial torque adjusting For 41301-JS401 : T=0.1mm
1993 1998 JZA80 2JZ-GTE 40101-TA401 LSD Shim, initial torque adjusting For 41301-JA800 : T=0.1mm
1993 1998 JZA80 2JZ-GE 40107-MZ202 LSD LSD Clutch Plate set For 41301-JS401 : For replacement
1993 1998 JZA80 2JZ-GTE 41301-JA800 LSD LSD (for Turbo 6MT only) 5/93 - 8/98 : Clutch type 8.7", 2 ways
1993 1998 JZA80 2JZ-GE 41301-JS401 41301-JS402 LSD LSD (for Turbo 4AT & Non-Turbo 5MT)*** 5/93 - 8/98 : Clutch type 8.0", 2 ways (See Side shaft section)
1993 1998 JZA80 2JZ-GE, -GTE 41309-24020*** TOYOTA OE PART LSD Side Shaft for Torsen LSD Supra Require for 5/93 - 7/96 5MT w/factory LSD & 5/93 - 7-96 4AT Turbo
1993 1998 JZA80 2JZ-GE 83001-JA800 Meter Meter set (for 93 - 96 NA model) Speed : 320km/h, Tacho : 10,000rpm, Volt
1993 1998 JZA80 2JZ-GTE 83001-JA810 Meter Meter set (for 93 - 96 Turbo model) Speed : 320km/h, Tacho : 10,000rpm, Boost : 1.2kg/sq.cm
1993 1998 JZA80 2JZ-GE 83001-JA820 Meter Meter set (for 97 - NA model) Speed : 320km/h, Tacho : 10,000rpm, Volt
1993 1998 JZA80 2JZ-GTE 83001-JA830 Meter Meter set (for 97 - Turbo model) Speed : 320km/h, Tacho : 10,000rpm, Boost : 1.2kg/sq.cm
1993 1998 JZA80 2JZ-GE, -GTE 83110-JA800 Meter Speed Meter (93 - 96) 320 km/h
1993 1998 JZA80 2JZ-GE, -GTE 83110-JA810 Meter Speed Meter (97 - 98) 320 km/h
1993 1998 JZA80 2JZ-GE, -GTE 83242-JA800 Meter Tacho Meter (93 - 96 for NA 5MT) 10,000 rpm
1993 1998 JZA80 2JZ-GE, -GTE 83242-JA810 Meter Tacho Meter (93 - 96 for Turbo 6MT) 10,000 rpm
1993 1998 JZA80 2JZ-GE, -GTE 83242-JA820 Meter Tacho Meter (96 - 98 for NA 5MT) 10,000 rpm
1993 1998 JZA80 2JZ-GE, -GTE 83242-JA830 Meter Tacho Meter (96 - 98 for Turbo 6MT) 10,000 rpm
1993 1998 JZA80 2JZ-GE 83243-JA800 Meter Combination Gage (93 - 96 for NA 5MT/4AT) Volt, Water Temp., Fuel
1993 1998 JZA80 2JZ-GE, -GTE 83243-JA810 Meter Combination Gage (93 - 96 for Turbo 6MT/4AT) Turbo Boost, Water Temp., Fuel
1993 1998 JZA80 2JZ-GE, -GTE 83243-JA820 Meter Combination Gage (96 - 98 for NA 5MT/4AT) Volt, Water Temp., Fuel
1993 1998 JZA80 2JZ-GE, -GTE 83243-JA830 Meter Combination Gage (96 - 98 for Turbo 6MT/4AT) Turbo Boost, Water Temp., Fuel
1993 1998 JZA80 2JZ-GE, -GTE 12180-SP020 00602-12108-003 Oil Filler Cap Oil Filler Cap Twisted type
1993 1998 JZA80 2JZ-GE, -GTE 90915-SP020 00642-90915-001 Oil Filter Oil Filter
1993 1998 JZA80 2JZ-GE 33530-JX000 Quick Shifter Quick Shifter w/Shift knob For 5 Speeds MT only
1993 1998 JZA80 2JZ-GE, -GTE 16401-SP030 00642-16401-003 Radiator Cap Radiator Cap N-type : 1.3kg/sq. cm
1993 1998 JZA80 2JZ-GE, -GTE 71100-SP020 Seat TRD Sport Seat Black/Gray Fabric with TRD Sports Logo
1993 1998 JZA80 2JZ-GE, -GTE 71100-SP050 Seat TRD Sport Seat Red/Gray Fabric with TRD Sports Logo
1993 1998 JZA80 2JZ-GE, -GTE 72101-JA800 Seat Bracket, seat, right For TRD Sport Seat only
1993 1998 JZA80 2JZ-GE, -GTE 72102-JA800 Seat Bracket, seat, left For TRD Sport Seat only
1993 1998 JZA80 2JZ-GE, -GTE 48510-JA801 Shock Absorber Shock Absorber Assy, front Non-Adj. ; Bilstein ; 438/105 for Street
1993 1998 JZA80 2JZ-GE, -GTE 48530-JA801 Shock Absorber Shock Absorber Assy, rear Non-Adj. ; Bilstein ; 259/65 for Street
1993 1998 JZA80 2JZ-GE, -GTE 53607-JA810 00602-53607-007 Strut Tower Brace Strut Tower Brace, front
1993 1998 JZA80 2JZ-GE, -GTE 48000-JA801 Suspension set Suspension set Shocks (Bilstein) and springs
1993 1998 JZA80 2JZ-GE, -GTE 48130-JA800 00602-48130-006 Suspension Springs Lowering Spring set For street ; 1.0" lowering : Front K=11.0 kg, Rear K=9.4 kg
Word.
Thanks guys, I tried the search (one of the rare occasions it worked for me) for "TRD parts" and came up with over 800 topics:rolleyes:
Curt, did toyota ever have a catalog with all the trd parts in it?
Dave
I think there is a master catalog available. My old TRD catalog, which seems to contain a limited number of parts, says you can order an "TRD All Parts Catalog" from a Toyota dealer.
1st Lieutenant Team BEYAW
well, just from your sig pic, it looks like your missing the TRD speedometer MVP has :)
Dave
Catalog not needed, Above IS the TRD parts list for MKIV..............
1 - 8 of 8 Posts
