Blue 03 cobra I wish :)
anyone ever had this problem before shit , :(
my apexi fmic bottom driverside bracket broke 1in.wide 1in height
hole on it , can this be fixed or do I need to buy new intercooler
ken w/t78
Is the hole in the tank?
Because you can take it to a good fabrication shop with a tig welder, and they should be able to fix it, the hole may not look pretty when they are done, but it will save you from buying a new one. Depends on how bad it is, some welders(like myself) could make it look good. :)
yes , hole in the tank
I was thinking maybe I can put little aluminum 2in*2 weld it outsideof the tank
will that be ok
ken
Do you have a tig welder?
I'd take it to a shop, it may cost you a bit more, but usually you can get a scrap peice of aluminum. Hell if you wanted to be fancy you could have a apexi logo made from aluminum then weld it over the hole. A good welder can lay a perfect bead...
You can also take it to a radiator shop. They should be able to fix that.
Discussion Starter #6
I got it fixed at welding shop
wow , they did very good job :) $35.00
