I wanted to know if anyone has seen the effects that a Oil cooler has on oil pressure.... I think this time around, I am going to need one to drive around town.. but i need my oil pressure!! Thanks
X2. I have a line on an aircraft/AN line one I might install. It gets HOTT in this 'hurr desert!I wanted to know if anyone has seen the effects that a Oil cooler has on oil pressure.... I think this time around, I am going to need one to drive around town.. but i need my oil pressure!! Thanks
I'm not worried about lack of oil... just trying to figure out a way to keep temps as low as possible and oil pressure up.I have noticed no (-) change of oil pressure on mk3's and mk4's when I have installed oil relocation kits with air-air oil coolers.
One word ACCUSUMP!!!! Never spin a rod from lack of oil again!!!!
http://www.pegasusautoracing.com/group.asp?GroupID=OILACCUS&iorb=4764&0
Later Keith
I am asking these questions .. so i can see if i can make a 1/2 filled motor work on the street... where oil temp is the only issue.With MK4's as you know they cool oil with hot coolant.I don't think its a good idea. As for street use oil coolers do a great job of keeping oil temps down as long as they are placed in a spot where they will get sufficent air flow. Not stuck behind a huge 4-5 inch intercooler that will rob it from cool air.
And BTW most of a engine/turbo wearing times are on start up, now a pre-lubing system will cut bearing wear down alot. As I said Accsump. It's insurance I think anybody with a high horsepower engine should not be without.
later Keith
Ive heard that too, but it doesnt sound right. I had 10 psi at idle, in an sr20det, and I was told by several people this was ok.The rule of thumb is 10psi of oil pressure per 1000 rpm....just fyi.
T
Later Keith
From my knowledge, it's wasn't a filled block.hmm didnt ryan woons motor run the stock oil cooler with a filled block ?
1/2 filled should not be a problem, being only 1/2 filled your still running some coolant............right??I am asking these questions .. so i can see if i can make a 1/2 filled motor work on the street... where oil temp is the only issue.
It was partially filled block per emails I exchanged with Ryan about a year or so ago.From my knowledge, it's wasn't a filled block.
1/2 filled is a known problem with oil temp. With a half filled block, there is no coolant running through the bottom of the block. i dont have a "stock" oil cooler and I have not had good luck with the sandwich adapters...1/2 filled should not be a problem, being only 1/2 filled your still running some coolant............right??
Size and placement of the cooler is the key.........if you get a large enough one, one to run a small fan to help always have a consistent amount or air flow running through it (like at a long stop light or just on a oil temp that you feel comfortable with) you will be fine.
Later Keith
then your knoledge wasnt complete. his was half filled. he said so himself.From my knowledge, it's wasn't a filled block.
I said it wasn't filled, where did I say it wasn't half filled?:nono:then your knoledge wasnt complete. his was half filled. he said so himself.
screw a oil cooler.. i've got another solution![]()
Alcohol? No, i dont have to cool oil anymore... well no more than before.what? Alcohol?
I have to make the oil cooler decision too, so please share :wavey:
