1 - 13 of 13 Posts
One Slow Supra
I need some info really bad. My car has PHR Stage 2 curently with 1200cc injectors and map ECU. Running super rich, I was wondering if I change with Siemens 850cc would be ideal and tunable. How much horsepower can I make with pump gas and race gas? Thanks for the info guys....
Hardtopper
You should be able to tune the 850's MUCH better than the 1200's. The 850's will support all the HP a 67mm could make and then some - approx 850-900HP at the crank.
One Slow Supra
Do you know if siemens injectors are any good? Thanks for your info.
Hardtopper
Seimens makes a good product. They're widely used successfully on multiple platforms.
One Slow Supra
Eventhough with Map Ecu? I know standalone will work fine....
I had 850cc Siemens injectors (I got them with my PHR Stg 2 fuel kit) and ran them with a gForce moded stock ECU and a MAPECU when I had my small single (PHR Stg 1 on a cast manifold). It ran great for many years. They are a quality injector from everything I know...although I had one freak fail on me last year so now I'm using ID1000's.
SICK OF THE NUT SWINGERS
Rocky I made 614 rwhp 91 oct on those injectors with map ecu 1 (old set up)..fyi
One Slow Supra
Discussion Starter · #10 ·
Thanks guys, and yes I'm selling my RC 1200cc
Got boost?
i have siemen 850cc with BL67, i had it for 4 years.... works great!
1 - 13 of 13 Posts
