1 - 8 of 8 Posts
Alpha for president
tim, i know i talked to you today about this line on the top of the pump under the throttle body....but i cant find a picture to be 100% that i mod it the correct way... you said it was simple but i want to do it right..
thanks
Alpha for president
well.... i guess i should have said the fitting that on top of the pump rather then the hose itself...it hits the t-body
DO WORK!!
the only pic I have is one on the car. I will try to explain.
if you took a straight piece of pipe and cut a 45 degree cut in the middle of it, then take one side of the cut you made and turn it 180 degrees. You now have a pipe that is a 90.
you are doing a similar thing to that small pipe that comes off the PS pump.
Make a angled cut near the base of the pipe.... rotate the cut piece until it no longer comes in contact with the TB.... Weld it up and bolt it back on.
I will keep digging through my pics and see if I can find something for you. Or i could just make you one for a small fee!
Thanks!
Alpha for president
ok thanks....did that bracket get sent out today??
Alpha for president
ok thanks
Alpha for president
Discussion Starter #8
1 - 8 of 8 Posts
