Hi guys,
BBC: the one that our tech is making, provides a steadier upper bound on the signal. The Greddy had some kind of noise, not probably noticeable by the Supra ECU, probably because it incorporates switches for other vehicles. On ours, we used just the straight needed Supra circuitry. Result, no noise at all, and steady signal at either 4.1 or 4.3 or of course anything else, depends were you set it.
As for the kit, it's not as I said again and again rocket science, the components are out there, and anybody can purchase most of them from different manufactures. We are just getting a very good wholesale price from them, because of previous business and we just add a 15% for our time, that's about it. We just added the little pieces of the puzzle together and added some more and there it is. As for individuals that already got the manifold, the turbo and the wastegate, no big deal, we can sell them all the other needed items, so they can complete the kit.
As I repeatedly said we prefer to sell DIY kits or components, because the lead time is approx. 2 weeks if not earlier. The full kit has lead time about 4 weeks. DIY kit is only $1,660 without the charger and you basically have to weld the DP, port the WG port with a dremel and weld the small connector of the WG, that's it.
As for the complete kit without the charger is $2,100 and we can actually fit any kind of turbo you want V-Band, on center etc. If we don't have the housing, you can send it to us and so we can make your DP and then it will be returned to you (at this time you also got the option of having it ceramic coated inside-out for a small price, since you went through the expense of mailing it to us).
Just to verify which BOV is included in our kit, basically none, that's the customers choice. I know almost everybody on BPU has another BOV (leaky stock BOV). So why put it in the kit, extra expense (not very intelligent). If you want one, I'll send you one for a very competitive price.
check us out
www.directedengineering.com
Best Regards,
Dimitri I. Keramidas
