Toyota MasterTech
I made my own, but it should fit just fine. It will drop straight downward then route to the intercooler. It doesn't go through the fender like the greddy piping does. It's actually 2 sections of pipe with 4 pipes total. Two are just welded together so only one coupler is needed between, it allows for slightly different angled setups, and its easier to install than a one piece. I actually never used this particular setup though... hope I helped.
Keep in mind, you will need the Twins Turbo t-stat rotator kit (or similar), along with shortening the radiator hose to run the drop down style piping. That is why all the OG IC pipe setups went thru the fender.
Al
