Well, I purchased some Titan bars, and I am replacing my HAs with JIC FLTA2s. I'll be at Sears Point next weekend, I'll post the results. Carl
How'd they do?in2twins said:Well, I purchased some Titan bars, and I am replacing my HAs with JIC FLTA2s. I'll be at Sears Point next weekend, I'll post the results. Carl
I'm putting this setup on now, can't wait to see what it feels like (taking off KYB AGX/Eibachs); should be a big improvement.in2twins said:Well, I purchased some Titan bars, and I am replacing my HAs with JIC FLTA2s. I'll be at Sears Point next weekend, I'll post the results. Carl
Carl, thanks for the info, now I'm excited to try out the car (it's been months waiting)in2twins said:I will write a more formal review on the bars later, but, in short I liked them very much. For 275-40-17 rear, and 255-40-17 front V700s the car was perfectly neutral, with oversteer available as needed on a BPU car. There are many pictures of the car coming through the turns at Thunderhill raceway on this forum. Go to "500 pics" etc thread, and look for the RSP 97 on pages 8-9-10 of the pictures. the rear bar is a little stiff for the tire sizes I used as the rear bar needed to be full soft(1 of 3), while the front was full stiff(2 of 2). With the 275 front/315 rear that most road racers run the bars would be spot on, with the middle setting being used generally, and the other two positions, as needed.
I had the JIC FLTA2s set on full stiff in the front, and 12 of 16 in the rear. I might have been able to increase the damping in the rear a bit, and move the bar, but the car was behaving so well, I decided to leave it alone. The next time out will be April 10th at Sears point, and I should be a PT67 .68P trim with fuel, and Race Logic by then. I will of course test initially with the Race logic off. So all in all, the bars had the range of adjustment I needed, and the car did not exhibit any of the "skittering" that some road racers have complained about with the BA TRD bars. The track is fairly new, and the surface is very good. Also the car was absolutely "flat going through turn 1, a ~100mph sweeper. Hope that helps, I will be autocrossing the car in about a month as well, so they will be put to the test again, at that time. Carl
hahaha. not only does he not track his car, I don't think it has actually been DRIVEN since he put them on.in2twins said:Jim Swantko has the Whitelines, he likes them, but I do not think he tracks the car. Carl
Lemme know when you want to line 'em up on 540 .... what a cute little turbo you have. :ghey:turbomx5 said:hahaha. not only does he not track his car, I don't think it has actually been DRIVEN since he put them on.
hahaha
