1 - 12 of 12 Posts
I was at the machine shop and was shown some trick yota lightweight buckets. No shims was pretty trick as well. So is anyone using them?
Iam using the "Shims under the Bucket" conversion from Arnout (NL) which should allow rpms to about 10.000 with some other mods. They are much lighter then the original one and work fine, now over 20.000 km.
left: original
right: shims under bucket.
quick said:
Yes. They're the shimless buckets from the 3S-GTE IIRC.
Not many people do it due to cost tho.
close, but not quite:) they are from the 1zz-fe spyder.
wastegate hose is pulled
Did you go down to Lab Kerri? I brought Rich there the first set for my 7M. They work pretty well. Not needed unless you are going beyond the norm with big cams though. IIRC, the Echo has the proper size for the 2JZ. Price wasn't too bad from Jeff Watson.
1 - 12 of 12 Posts
