in the morning, ill take a picture for you.
2 RIP
2 RIP
2 Hoses??? Mine only has one vacuum hose.AKA SIR said:I am installing mine this weekend and I am not sure where the two hoses go. According to the GReddy manual, one goes to the fuel pressure regulator and the other goes to the intake manifold.
Can someone please explain to me where these are? Or better yet have a picture!!! I looked at the MKIV.com 52mm boost guage install in the tech articles, but that one is a manual guage and only has one hose to hook up, not two.
THanks in advance.
Jeff
Are you sure yours has two vacuum hoses? I just bought a 60mm greddy boost with peak/hold warn, but it has only one connection for one vacuum hose?AKA SIR said:I am installing mine this weekend and I am not sure where the two hoses go. According to the GReddy manual, one goes to the fuel pressure regulator and the other goes to the intake manifold.
THanks in advance.
Jeff
Thanks for the clarification!Black95TT said:If you look at the diagram again, you will see that the new components you are adding to your car is the sensor, ONE VAC HOSE, and the Tee. You will cut the Vac hose from the FPR to the Intake Manifold and put the tee in there to rejoin the line. You then add the ONE VAC HOSE that goes to the pressure sensor box to the third point of the tee. That is all, so it is basically tapping the FPR vac line to run to the gauge sensor box. In other words, the air coming from the intake manifold, that used to only run to the FPR will also run to the gauge sensor now.
Hope this helps. Didn't mean to yell with the caps, just trying to be clear.
Peace,
Mark
