·I purchased a vpc from someone on supraforums but have had some problems....i need help with the harness that plugs the temp sensor and the pressure sensor into the vpc itself.... someone cut the end off from the pressure,temp sensor to the vpc so i have bare wires i was just going to hardwire them to the vpc all the colors are the same but one . on the vpc i have a grey wire, and on the harness to the sensors i have a white one... all the rest of the wires are the same... i need someone to check their vpc to see if the colors are the same exept for the white and grey wire... thanx Kevin.... if need call the house i really appreciate it.... 937 432 6443 ps it is the white female fitting from the harness to male on the vpc...
