1 - 11 of 11 Posts
anybody install a s-afc with vpc on their supra? my car wont run right after i install the vpc. it run for like 10 min. and it start to run like i had 5 cyl. any body know what i need to do?
the vpc did you hard wire it in or did it come with the harness?
Do you have the right chip in the vpc for your particular setup?
quikturbo said:
what do you mean "change any wires"?
I installed the vpc and afc at the same time. I ran the vpc wires into the afc wiring, then to the ecu.
i donot have afc, but i have gcc and vpc, i think should run wire from afc to vpc first, then run your vpc harness or hardwiring vpc into ecm, right?
:rolleyes:
Sleeper King
I don't think it really matters which set of wires go to the ecu (afc or vpc) as long as they find there way to the right position. I didn't have the harness. therefore, my afc wiring was longer than the vpc wiring. Thats why I used the afc. My car idles like a dream and throttle response is perfect. I guess my connections are just fine.
chris
T78
Discussion Starter · #11 ·
ok its like this, i had the afc for a while now. i was using hotwire sensor type. and now mass air is out i cant use hotwire anymore. so iam asking where do i hook up the airflow/pressure signal wire to. now i only had the vpc hook up, i started up it ran good for like 10 minutes it starts to die, like running on 5 cyl. i think it flooded too much gas. i got 720 injector 18b chip so its the right chip. i think i need to lean it out with the apex afc. any will be appriciated. sonny
1 - 11 of 11 Posts
