:stickpoke will the apexi afc II take care of my fuel cut prob. i dont think it will but some kid told me it would. i mean this by it self no bigger injectors no lex.
Actually with a good tuner you can raise it up pretty high with a AFC.91supraT said:an afc wont do much about fuel cut, gotta get a fcd, or standalone, or 550/lex combo or something most piggybacks by themselves dont eliminate fuel cut. a year or 2 ago i had a rebic LC and that got rid of it and rev limit, anyway afc wont do much.
Trent said:Actually with a good tuner you can raise it up pretty high with a AFC.
If you have a MKIV or walbro pump, AFPR, Lex/550's, you can effectively make fuel cut almost non existent. The only time it might come into play is when you may want to use race gas and turn up the boost. I ran two of my setups to 20-22psi on the Lex/550 setup and never hit cut. It all depends on how your tuner takes care of your map. If he does it right, he can raise it to a point that you probably won't ever see it.
