T
Thrifty
·Guest
Does anyone else have the AVC-R AND the S-AFC?
I'm wiring them both up to my car's wiring harness right now and have run into a bit of a question. Both controller's require you to hook up two ground wires in sequence before the Main ECU. They obviously must be in a order, but the question is,,,,,Does one controller go before the other???
If all four wires have to be hooked up, then how do I insure that one isn't scrambling the other??
If clarification is needed, someone let me know.
Thanks, Thrifty
Thanks, Thrifty
