1 - 4 of 4 Posts
Do you have to remove the bushing from the bar to add grease or will just smearing around the edges and on the bar be good enough? Do I need to have the car jacked up or can it be done without jacking it up? Thanks.
· Old School
Don't you have grease fittings in the brackets?
My bad if that is the case. I had them installed at a shop and have not looked at them close. The pics I have seen for install showed the bushings smeared in grease before the install. I will look for the grease fitting in the morning, can you get to them fairly easy or do you need to jack up the rear end? Sorry for the dumb questions.
· Old School
Getting at them depends on how low the car is. The rears are easy.
1 - 4 of 4 Posts
