Over the last week - sometimes the following lights come on for no apparent reason (at least not apparent to me).
Lights are MIL, trac off, and check engine.
This first happened after going to the dyno a week ago - this was the first time I had actually pulled the trac fuse and EF1 and EF2 fuses.
The fuses look fine, the contacts look clean, they are in firmly.
If I pull all the fuses again and clear the ECU - the lights go off.
It may take only minutes or a couple of days until they come on again while driving.
Main question - is this a problem ??
What should I do?
What should I do?
