1 - 20 of 35 Posts
· Under Construction
I was wondering why most people are going with twin walboros instead of twin OEM pumps? Is it because of the price? Have you guys had your walboro pumps fail on you? Let me know. Thanks.
Multiple walbro failures here. Couldn't ever find out why. I ordered twin pumps from Denso ~ 150 each. Same ones you buy from Toyota. They are working flawlessly. Almost lost a motor when the car went lean.
Now I have an A/f warning light wired from the AEM so even if one of my denso's fail I'll know it as soon as it happens even if I'm not looking @ my FJO.
· My boss set me on fire!?!
One of the problems with the Walbro pumps is that the clearance is so tight in them (in order to get the high flow in the small package) that any small bit of trash that makes its way into them is enough to damage it. Very often it seems that the failures are after someone running low on gas. I have seen inside many of Walbro pumps that are bad and you can see the trash on the inside of them.
Either way I am going to run two MKIV pumps. Ill deal with the current draw.
Danny
· Premium Member
Twin stockers... and will stay that way.
· Super Moderator
Except for the amount of current they draw, the stockers are superior to the Walbros and every other equivalent pump in the marketplace. For the life of me, I have never been able to determine how the switch over to Walbros began in the first place. It is rare, very rare, that you are going to be able to beat Toyota R & D. This isn't one of those occasions.
Ken.
I have 2 walbros, seems to be holding up fine. Ive had them in for maybe 2 years, fuel pressure on my car has been fine.
The few advantages are lowered draw and smaller size. Yet, I have seen many people report walbros giving them inconsistent fuel pressure.
Stock are best IMO, but are not considered cost effect when compared to the walbro pricing.
I have twin walboros... and I still am having problems with them... I just recently went back into my tank for the 6th time to figure what is going wrong.. So, i replaced the in-tank hoses. No my FUEL PRESSURE bounces all over the damn place... at idle it will hop around like mexican jumping beans from 42lbs-50lbs..... the fuel pressure doesn't even rise 1 to 1 with boost....
Is one of my pumps dead????
I am tired of this shit...
I've probably been in the tank at least 6 times in the last year. Sucks! I hope I never have to open the tank back up again. Why don't you test your pumps to see if one is dead. I wired mine up with quick disconnects so I can easily test a pump. When I first noticed problems w/ my Walbro's they would support around 680rwhp and that was it. I replaced one and made 801rwhp. Everything looked good for 3 months and then had a few more failures.
Danny
Danny I never found out why mine failed but I like your explanation. I don't really get on my supra anymore once the gas light comes on.
1 - 20 of 35 Posts
