1 - 3 of 3 Posts
I seem to have misplaced the oil return flange that I had with my Supra oil pan. I have the one from the Aristo, but it does not seem to line up right, tho I replaced the horizontal oil return hose. Do I need to replace the vertical hose with that of a Supra 2JZ? I't doesn't line up right (without kinking the hose), since I replaced the oilpan.
Basically, this flange that connects to the oilpan has 2 inlets.... Is this flange the same on both the Aristo oilpan and the Supra one? Will I just need the upper/vertical hose?
I did search and search is not my friend today.
E
The aristo pan is a front sump pan and the supra a mid/rear sump pan...the turbo drainback flange/pipe is a bit different as I recall...
1 - 3 of 3 Posts
