aristo water pump differ from supra 2jz water pump?
4373 Views 1 Reply 2 Participants Last post by  tlo86
I bought a aristo 2jzgte swap for my 240sx went to replace the water pump found out that its different then the supra 2jzgte water pump, any idea where to find this pump at, any help would be appreciated, or should i go with the 2jz supra pump and buy the housing and pulley, any differences in the the two. thanks
mark
1 - 2 of 2 Posts
aristo = hydraulic fan setup
mkiv supra = clutch fan setup
if you are using electrical or clutch fan setup stick with the mkiv supra water pump
if you have a hydraulic fan setup use that water pump
you cannot run the aristo water pump with the clutch fan. if you try to use it with an electric fan it will die fast (the hydraulic system is built into the pump it'll mess things up trust me :p)
1 - 2 of 2 Posts
