· My mind is forged
Hi, I think my first turbo is turning off to fast. Do you know from which to which rpm should work 1st turbo and 2nd?
the first turbo doesn't turn off, second turbo comes on with the first turbo at around 10psi
the *sequence* is
turbo 1 --> turbo 1 + turbo 2
· My mind is forged
Than why my first turbo is turning off around 3.000 rpm - I am sure 100%, I can feel that and hear as well.
What could be broken?
I've noticed that: if I accelerate from 1000 rpm up, at 2.300 rpm 1st turbo kick in and around 3.000 rpm it goes off but if I stop accelerate for second and start again (3200 rpm) it will kick again and turns off after few seconds and again if I stop accelerate for one second (3200 rpm) and start again it will kick. If I do not stop accelerate it would not kick.
Please help
There is a pressure drop between the transition from #1 to #2. This drop may feel like #1 is shutting off, but what is happening is once a certain rpm is reached a valve opens up to allow #2 to come on, this valve when opening and filling the #2 turbo with air takes some pressure off of #1 which causes boost to drop and then kick starts #2..this where you get that big kick in the ass!
· My mind is forged
Is it around 3.000 rpm? and last from 3.000 to 4.000 rpm when 2nd kick in?
