L
labrat
·Guest
Are you running a T78 and if you are do you like it as a daily driver?
Originally posted by labrat:
<STRONG>Are you running a T78 and if you are do you like it as a daily driver?
Thanks</STRONG>
Originally posted by Jesus:
<STRONG>Yes i like the turbo, is a great piece, barely no lag, just about like stock turbos,[/QB][qb]</STRONG>
Originally posted by PHR-Single:
<STRONG>
Jesus - I respect the huge #'s you put down, however - I had a T88 and would bet that the T78 isn't that much different. Basically, there is NO WAY a T78 spools anywhere near the stock twins. While a T78 may hit hard at 4k or less - the time it takes a big T-78/88 to get up to those rpms is substantial. Very apparent when racing...
Jay</STRONG>
<STRONG>Did you put a stall converter on it?</STRONG>
Originally posted by Twitch:
<STRONG>Jesus were you parked near a Suntrust bank near the Publix on the corner of Alafaya and Colonial?</STRONG>
No...I'm with you on your full boost at 4400rpm - my point was that the stock twins can get to 4400rpms, much faster than a T78 can. It's not a question of when full boost hits....just how long it takes to get to the same # of rpms!Originally posted by Jesus:
<STRONG>Jay: So you are doubting about my honest opinion ? you can see my dyno sheet anytime in the MKIV site, on my car i have full boost around 4,400 rpms, if you see basically when you have stock twins and full power its around 4,000-4,500 rpms. T 88 is a HUGE difference from a T 78, the T 88 flows 23% more air than the T 78, bottom line is the T 78 is perfect for the street anyday anytime.
[/QB]Originally posted by PHR-Single:
[qb]
</STRONG>
<STRONG>No...I'm with you on your full boost at 4400rpm - my point was that the stock twins can get to 4400rpms, much faster than a T78 can. It's not a question of when full boost hits....just how long it takes to get to the same # of rpms!
Either way....I agree that the T78 is proven turbo. Good luck on your new T78/Automatic Supra!!
Jay</STRONG>
