i already talked to boris, i am down to do the 6 speed swap, and kou is down to modify the tripod and shifter linkage and i got most the parts to build the diff factory clutch type posi, new clutches, solid spacer, all new diff bearings & Seals, but need to find a 3.73 ring & Pinion, what clutch are you guys planning to run? and we can get the driveshaft made when everything is done, your car should be done and running end of this month lol, and i need to have someone detail the car, for some reason the clear on this thing is just, horrible, after a bird turd is on the car no longer than 10 minutes, it already stains the clear coat!
airsoft guns james! this shit is so real and i can shoot people and they won't die!
