I followed the same directions but used the screw supporting the radio as ground.mkivmatt said:
Maybe I should have specified that i've been using those instructions. I've had no problems, EXCEPT FOR THE CONNECTION OF THE GROUND AND POWER WIRES! Next time read my posts before making smart ass comments that aren't needed.![]()
Qualen, what do you suggest?
I'm still waiting on someone to inform me about proper way to connect the power and ground wires. I know where, I don't know how. Please help and don't just be a smartass.![]()
hurry4it said:If you still have the dash apart just connect the negative to the metal dash connectors behind the dimmers switch panel and then tie the positive into the dimmer swicth on the undimmed positive wire. I want to say the color is white with and orange stripe. Just plug the positive wire into all three wires till you get the indiglos on solid (make sure when you are doing this that the dimmer is not plugged in.....Hope this helps...I have done it on all the cars that I have owned including the supra and it works great. Just make sure you get a good connection on the positive wire. Using a wire tap works the best.
Adam
