im gettin ready to start putting in the SP fuel system and had a few questions. i called a few weeks back when i received the kit and talked to tom? i think about the wiring but i need to double check what goes where before i start. heres what i have wrote -down
-purple wires on relay- power at battery
-blue and green wires on relay- red pump power wire
-red/black stripe and red wires on relay- blue/red stripe wire on the harrness that runs through a grommet that is in the upper left hand corner around where the fuel pump bracket goes.
-black and black/red stripe wires on relay- white/black wire on the harness that goes on the top of the fuel pump bracket.
the last wire is the only one im not sure about, i cant remember if it was that harness or not.
Also, how should i route the power lines from the relay to the battery? just run them the same way the stock fuel line goes, under the plastic guard? and last, when i hook up the fuse, do i cut the wire loop and connect one end to the battery, then the other end to the power wire coming from the relay?
Thanx
EDIT: oh yeah, also, can i hook up the power/ground wires for one of the walbro pumps into the stock plug in the tank then cut the stock wire when its on the other side of the plug(out of the tank) and then use the supplied wire? or do i need to run 4 separte lines out of the tank?
Thanx
