auto 2 6spd conversion
322 Views 4 Replies 1 Participant Last post by  lotaboost
does any1 here know what exact parts are needed to convert a auto supra tt to a 6spd. this would be really helpful info
I just converted my 88 supra to a 5 spd. I imagine it would be a similar process. You'll probably need the tranny, master and slave clutch cylinders, the clutch and brake pedal assemblies, clutch line, 6spd flywheel and clutch, possibly the cast iron bottom mounting brackets and the inspection plate covers. It took me a couple of days cause I was hunting down parts and it was my first time. You should be able to do it without pulling the motor.I did. You need to find out the differences, if any, between the bell housing bolt patterns, and make sure you have all the necessary parts. I think the auto diff. is lower geared so doing the conversion you should have better acceleration on bottom, but your top speed will suffer. Check your diff. gears to find what you want. Everything should just bolt right up.
i am considering doing the swap if you interested in trade
One of the hardest parts is that the trans tunnels are different. Toyota sells the proper tunnels for both cars so you just need to cut out the old one and weld in the new. We just did a 6 spd to auto conversion.
Lar
SP
What would be a rough estimate on labor for the swap from you guys....( Sound Performance)..oyea by the way if i did the swap your tranny and converter will definately be in my car. A friend of mine bought your stall and tranny and has nothing but good things to say about it.
