Will a JDM or aristo automatic 2jzgte transmission fit in a US spec car? If no, then what mods do you have to do?
yea it will fit. They're the same trans. The aristo trans might have the line pressure regulator set lower than the supra trans though (for smoother/slower shifts), in which case, you'll want to set this back up to "high"freshjive1682 said:Will a JDM or aristo automatic 2jzgte transmission fit in a US spec car? If no, then what mods do you have to do?
Is this true? has it been confirmed? I'm in need of replacing my transmission and found a jdm transmission for $175 close by.yea it will fit. They're the same trans. The aristo trans might have the line pressure regulator set lower than the supra trans though (for smoother/slower shifts), in which case, you'll want to set this back up to "high"
If this is the case, you'll have to open the trans to do it
Gene
You can also change out the tail flange to a supra. Very simple, but you'll have to cut the centering shaft off the rear of the aristo. Pretty basic really. And cheaper than a custom driveshaft. Our one piece driveshafts can mate up to either flange, we have adapters for both.Aristo trannys do not have a yolk shaft like the us auto supras. If you are doing a aristo tranny swap, you will need to have the aristo drive shaft or have one custom made.
