1 - 8 of 8 Posts
I have an 88 supra N/A with an automatic transmission. The car started shitfting at 5000 RPM two months ago. I did reset some fuses, replaced the transmission fluid, change the ECT unit box still did not help, I finally replace the transmission and the torque converter yesterday, the car still change gear every 5000 RPM. I just cant think of anything else to check on the car. I will appreciate any advice.
just taken a wild guess, kick down cable(i belive thats what he^ is talking about) it control the amount of pressure or somethin in the tranny, it sort of tells the tranny when ur on it or not. so if it broke(like mine) it wasnt sure when to shift and was really clunky but mine didnt go above 3.5k, so maybe yours it to tight? i dont do autos, talk to slow66 he has a built auto supra great guy too
josh
Captain Hammer
On the A340E, the transmission we have in our cars... are fully electronic, except for the line pressure. The "kick down" cable is the line pressure cable. It keeps lower pressures to provide smoother shifts, but when you are pushing it hard, or making more power, is when the cable opens the detent and increases pressure, will not affect shifting.
As Dean said, something in your TPS isn't right, that is where the Trans ECU gets it's info of how much you are "getting into it"
Thank you for all you guys that responded, I appreciate the advice. I think most likely the problem is the TPS, that is the only thing I have not check in the car. I do have extra TPS laying some place. I will replace it tommorow, but if this dont fix the problem could it be the main ECU box?
1 - 8 of 8 Posts
