1 - 4 of 4 Posts
Help guys , i have a Autometer Pro comp trans temp guage in the corner of my trans sump thats next to the DP , could it be picking heat up from the DP ????
as the reasdings seem very high , i have 3 coolers and it reads 210 when giving it stick , when it reads 180 i took a reading off the sump with a infra red gun and it read 60 degrees centigrade the guage reads in farenheit though and the coolers read 50 C !!!! what do you reckon is the brass union getting heat soaked by the DP heat ???
Dude
How long have you had this setup? Did it always read hot? It is very possible that the down-pipe is causing some heat soak, but how close is it really? You could just try to put a thin aluminum heat shield between the two and give it a try. :dunno:
1 - 4 of 4 Posts
