·I've installed WOTM 6-puck clutch kit, and have ran into some problems.
The clutch disk was installed following the Toyota Service Manual - taller cone portion of the friction disk towards the front (flywheel).
When I press the pedal, as I'm pressing it, half way down OR up - it chatters (actually more like grinds). Doesnt matter if I'm in Neutral, or in gear (driving). Each pedal travel cycle ends up in grinding noise half way into it.
After talking to Ryan Woon, he said disk installs the other way around, the taller cone (on the 6-puck disk) towards the back of the car (facing tranny). He also said he got only one Supra running properly with WOTM clutch - when cone was facing the flywheel, but that it should be the other way around. Damn thing came with no instructions, how was I supposed to know that?
I am using this with resurfaced stock flywheel.
If you are using the same clutch, how did you install the disk? Any similar sounds/problems?
Thanks.
Thanks.
