Eric,
I believe you have the newer unit (20 volts) where I have the 18 volt one. I only have a red wire, black wire, white wire, and green wire. The black is ground, the green is used for if you want to connect a switch so that you can shut the unit off or turn it on, the red and the white connect to the wire that leads to the coils. I suspect that you just cut the black with orange wire that you say is in the 10 connector and attach the red to one end, and the other end to the white. Is this right? Which connector are referring to anyways, the one on the drive side in the engine bay? Thanks for replying with this info. Glad someone is willing to help. Any more help would be greatly appreciated.
