1 - 20 of 41 Posts
ok so i went out to cecil county today. i only got 2 runs in cause ther was like 3 oil spills on the track and things were running really slow.
i was running open down pipe and CAM2 110 octane fuel. :):)
I REALLY NEED TIRES!!
here is the first run
60ft..2.4
1/8 mile 8.8
mph 89.9
1/4 13.1
mph ..116
second run
60ft. 2.4
1/8 mile 9.2
mph..87.69
1/4 13.5
117mph
as yuo can see i have hella topend. this SP61GT turbo is a monster. the first run was on 20psi and the second one was on 21 psi.. i really wanna take it up to 26psi.; but it pointless right now. on the second run i had to left off and get back on it due to my backend almost going out on me.
i have a feeling i'm making close to 500rwhp.. the car is an animal. i just need a good launch and better tires.
any reccommendation on tires???
With 116-117 mph trap speeds, I see low 12s in your future. I've been running 13.5s as well, but only at 106 mph.
2005 LP640
60ft..2.4
1/8 mile 8.8
mph 89.9
1/4 13.1
mph ..116
second run
60ft. 2.4
1/8 mile 9.2
mph..87.69
1/4 13.5
117mph
I don't get it.........does the SP61GT spool THAT fast? I have the full SP61 kit with the better turbine housing and larger A/R, yet I don't break traction for squat........granted I'm not tuned, but I'm on BALD tires. I get 1 bar of boost by 4,250rpm.
25psi = 14" brakes :)
What is your rear alignment settings? I have mine with almost zero negative camber. (As little as possible, the cams are all the way out to allow the rear tires as flat a tread patch as possible.)
The front settings are like stock, but with slightly less negative camber there too. (Hate wearing out the wider tires on the inside edges, and these tires grip so well, the negative camber seems pointless.)
I'm running 285/35 18 Goodyear Eagle GSD3's, and they grip really well, but could be roasted at will in 1-3, and could be broken loose in 4-5 with damp roads, or uneaven pavement. Boost would come on pretty quickly, but not as fast as a CT, but not much slower.
13's are dang fast for a road car. Don't sweat it. With drag radials, your going to run a solid 12 for sure.
I should have told you not to use street tires with the SP61GT at high boost. Its not only going to make it hard to drive, but its also dangerous. Last year(running only 18psi) on street tires my tires completely broke loose after my 2-3 shift with my car fishtailing at 65 mph.
Your mph looks about the same as mine at 20psi. When I ran 24psi last year I hit 119mph, but my car was overheating with a BHG, so it prpbably would have been over 120.
I can get 1.9 60fts with my 225 Nitto DR's on 300zx rims. I could let you borrow them if you are ever in the area.
Filmmaker
those are some crazy times, im only running like 15.4 and i was depressed but then again i have a crappy non turbo mk4 lol. Good job and get some tires and show us the 12 second slips!!! :bigthumb:
Matt
Yeah its funny how when you start making lots of power, our heavy cars don't like to move nearly as much as our rear tires like to spin.
Discussion Starter · #14 ·
that would be great.. yea i know my car will do 125mph+ i just need better tires and more boost
when this baby hits 88mph
mickey thompson et drag radial.
better than any street tire or drag radial. actually car craft or one of those did testing and the et dr cut better 60' than the et streets. i am never quick to recommend full slicks to anyone. if you have never driven a car with slicks it can be a handful in a hurry.
on a side note- congrats on the times! thats a very nice mph. just get those 60' down and you'll be in the low 12 range. keep at it!
dave
1 - 20 of 41 Posts
