·How much would i cost to buy a new left back panel and have it painted and fitted on the car. Does anyone know?!?! Thanks! (1995 mkiv)
If you are actually talking about the back panel, it's one piece and is an easy job for a bodyman. Drill out the spot welds and tack in the new piece. Now if your talking about the 1/4 panel, Moogie's right about the cost....more than the panel itself. You were pretty vague in your above post..blackNAsupra said:How much would i cost to buy a new left back panel and have it painted and fitted on the car. Does anyone know?!?! Thanks! (1995 mkiv)
ATLSUPDAWG#2 said:If you are actually talking about the back panel, it's one piece and is an easy job for a bodyman. Drill out the spot welds and tack in the new piece. Now if your talking about the 1/4 panel, Moogie's right about the cost....more than the panel itself. You were pretty vague in your above post..
can you post a pic? Maybe it can be fixed.blackNAsupra said:Well.. it got backed into and it is scraped/dented a bit.. does that help? do i need to replace the whole thing?
