Please!!! If anybody knows a way to get into the HKS ez boost controller installation instructions at MKIV.com please let me know. Right know the site is down for construction.
If you give HKS a call, they will fax you instructions specificly for the supra. The hardest part will be trying to connect the vacumm line to the presure tank by the fire wall. If I had to do it over, I would run my own line to the presure tank instead.
I now have all the lines hooked up except for the Pressure tank one. From what I understand from the install instructions I un hook a hose and put a hose cap on to each side.. Is this right? Fuckin assholes at HKS did not supply the full instructions. The stuff that I have has blury pictures. Please anyone with pictures would help me out alot. Thanks.
It's just after the firewall on the Drivers side. To get to it, put the car up on a lift or ramps. It's a major PITA. Why not just install it the blitz way? I tried e-mailing you the documentation from HKS but your mail server didn't like me too much Good Luck
