1 - 3 of 3 Posts
for some reason i am not getting a reading on the laptop for the tps. i have the brown wire of the map ecu harness soldered to the yellow wire (b43) on the ecu and it is not reading????????? could this be something wrong with the map ecu??????? anyone else run into this problem? my car is a 98 auto, dont know if the wiring is different.
last night i dissconnected the wire and ran the car and my trac control light started blinking, makes me wonder if i am on the right wire please any help will be great thanks.
Look at this:
An try to setup your map-ecu setting! It is easy to set it bad, so double-check all especialy the TPS seting
hmmm yeah i had it in the b43 wire and for some reason it did not seem to be reading anything. and i was unaware that if i have the setting all screwed up that will make it so it reads nothing :dunno:
1 - 3 of 3 Posts
