92 SC300 Aristo GTE
JDM ECU / MAP Based
So driving along this evening on the highway, get to the off ramp and sitting at the light I notice the idle is VERY low. like AT ZERO. Car is missing and I can see smoke out the side mirrors. Its dark so I couldn't tell what color the smoke was, but it smelled like rich smoke.
As I limped it the next 1/4 mile to my garage it got worse and worse to the point where I couldn't pull it in my garage. WOT yeiled 1100rpm and a lot of sputtering and smoke. Any load on the motor and it would stall.
I just got done swapping in the tranny and went for a quick little test drive and after pressing the clutch in 3rd I heard a pop and just figured it was the charge piping as I couldn't make any boost. These JDM turbos always had a little whine to them, I'm wondering if they finally shit the bed? Would it cause the car to stall and barely move, not hold idle, etc?
I checked the charge piping and it was all still connected as was the map sensor vac line and the IAT sensor.
It's almost like the MAP sensor was disconnected or something? Do the JDM ECUs have a limp mode if the MAP sensor failed?
JDM ECU / MAP Based
