Eat a bag
I found some nice rims (18x9/18x10)but the offset is +24mm. From what I know I need something like a 36mm offset so can I use spacers to make them fit? If I can, will it hurt performance a lot?
Jeff
I wouldn't. I do not feel like they are the safe way to go. The front off set should be +41-+44. I had a set of Racing hart Tracer's with an off set of +38 and used spacer, but pulled the rims and spacers off. The studs were almost to short with spacers. Now I have Racing Hart C5's with an off set of +41still very close to the big front caliper,but now the studs have the thread length that I want.
David B.
94TT
If you use spacers with studs instead of just a spacer, you will not have the problem of short studs. Many of the SCCA racers will use them to get maximum offset without comprimising wheel clearance. IMO.
Supra OG
Jeff
You do realize that with the 24mm offset wheels, you need the exact OPPOSITE of a spacer to get them to fit, right? Less offset = wheel sticks out more......
Andi
I agree that spacers should only be used to fill a void when using stock or very close to offeset. I have seen extremes and dont consider them very safe.
