Been having problems with running rich lately, and I'd like to check the VPC MAP sensor. Does anyone know how to check the voltage on one of these, and what the targe voltage is? Thanks.
Read Only
Check out http://www.chris.e-novate.ca/instructions/VPC/vpc.htm
in the "troubleshooting" section to see how to test the MAP sensor. I saved some hard to find documents over the years hope it helps.
BTW if by any chances you could tell me the voltage on the VPC output wire while the MAP & Temp sensors are unplugged it would be helpful for me as well. I think my potentiometer inside the VPC is out of wack.
Chris
Discussion Starter #6
I actually think it's my cam timing, but haven't had the chance to take care of it.
