If anyone has a chart or formula which converts "bar" boost measurement to "psi" and vice versa, would you please post it. Any related links also would be helpful.
94 TT 6-speed Targa
94 TT 6-speed Targa
Andi,Andi said:Just remember that everybody says bar but means kgf/cm2.... since *NO* gauges or boost controllers measure in bar.... they measure in kgf/cm2 or psi.
1 kgf/cm2 = 14.22psi
So when your greddy gauge says 1.2 kgf/cm2, that' exactly 17psi.. and 2.0 kgf/cm2 = 28.4psi
Regards,
Andi
That's the first I've heard of that. I stand corrected.Josh S said:
Andi,
My Apexi EL Electronic gauge units are "Reading x100kPa" so a reading of 1.0 on the gauge does in fact equal 1.0bar. I know a lot of people are running the Apexi gauges which read in Bar, while the Greddy gauges read in kgf/cm2.
Strange, maybe I have a freak gauge. Anyway I'm attaching a scan of the box that shows kPa. Wonder if mine is an old model, or a newer one? Anyone else have one like mine?Andi said:
I do have a question.... are there different Apexi boost gauges that read in different scales?
Andi
You could get an Autometer gauge, but a lot of guys on here will trash it because it isn't Japanese. Mine works fine. The only thing I wish I had was peak hold. But in 52mm (2 1/16") there isn't a peak hold. At least I don't think there is.dtalbert said:Thanks to all who responded. All the info is very helpful.
I have a follow-up question. I am in the process of going BPU and was trying to make a decision on which boost gauge to buy for the clock location. I want it to match the stock instruments (Black face / green backlight). Mohd tells me the only 52 mm eletronic gauge is the Greedy which reads in kg/cm2. Although I guess I can get used to the "bar" measurement, I really was looking for a 52 mm electronic gauge with the more simple (for me) to read p.s.i. Anybody know of another gauge which fits these requirements i.e. 52mm, electronic, black face, green backlight, p.s.i.?
Dale Talbert
94 TT 6-speed
