1 - 3 of 3 Posts
Gripless EGO
sup guys i ran into a little problem today when trying to figure out where the ground wires go that come off of the positive battery cable. THere is a skinny ground that i hooked up to the post that goes to the motor mount. Now i cant figure out where the bigger wire goes. I thought it went to the starter but i dont know where on the starter. I took a bolt off the front of the starter tryed to put it on there alll i got was a spark when i put the terminal on the battery so obviously its a hot. please helpppp
Turbonetics..****** asses
Dude ground wires dont hook to the positive battery terminal. They hook to the chasis of the car
Search
^^ What he said x209834239847234987
From the negitive terminal there will be two wires, one going to the block itself, and one going the the chassis
From the Positive terminal there are again, two wires. One going to the fuse block and the other, a thicker gauge wire, going to the starter.
To eliminate the problem of the wire sparking when you put it on the starter..... disconnect the other end from the battery ;)
1 - 3 of 3 Posts
