I currently have only the BCC wired into the car. Next week I will be adding the other 2 as I install a T 78 kit. I think I understand how to wire up everything except for the pressure signal wire for all 3. The AFR manual says to wire it between the BCC and the ECM.
Where does the pressure signal from the VPC tie in?(yellow wire)
Also, I bought the VPC used and it did not come with the 1200 ohm resistor that is called for in the instructions. Does anyone know what wattage rating that resistor is?
Thanks for any help.
