Hi, been lurking for a bit. Did a rebuild on my 7m and finally got it in. Did a R154 swap at the same time. Well this project has spanned 2 years. I can't find the bell housing bolts, or the starter nut/bolt or the stay bracket bolts. Does anyone know what size of thread and lengths these bolts are?
YotaMD.com author
M10 for sure. Lengths can be measured on the bell housing and block. Probably 50mm-75mm.
Tip: Common metric bolts will not be JIS standard meaning the wrench size is too large. If you can, get JIS bolts/nuts and you'll keep the great bolt/wrench size scheme that Toyota and other Japanese makers use.
