1 - 14 of 14 Posts
Ok minus the maf looking ugly, how much power is there to gain from using the vpc in the same situation as the stock maf? thanks
Yeah there is power to be gained but it all depends on your set up. I just got rid of my maf and it looks a ton better.
hum, i just wondering all things the same ona single turbo setup how much there is to gain. Need a before and after dyno, lol.
BLACKOUT
yea youll gain a little because of the tunning capabilities but the most important reason is to allow you to go further with your upgrades ....not too many people , if any run a maf with a single unless its a small single on stock fuel .....
whats VPC stands for??????????? im on stock maf, stock fuel...
Wasnt there a guy who dynoed with the VPC and did it with the stock MAF installed and without it. There was no gains with removing the MAF.
VPC = Vein Pressure Converter.
If your setup is in the 400-500 HP range, you dont need one. When you get up higher than that - esp if you add larger injectors, then it is definately a good idea!
Al
Working OT
you don't need a vpc if you have aem do you?
1 - 14 of 14 Posts
