1 - 20 of 25 Posts
What are the best 19" Tires?
I have Pirelli P-Zero's and need to replace them.
I have 19 X 10's in the back with 275-30-19's.
I want something that will launch better.
Moderator, Boost Addict
Bridgestone Pole Position SO3s. Great tires, just got a set and love them.
Adam
2
I also have the SO3's. There's a little road noise but not bad at all, considering the performance you get from them. They hold like crazy:)
Get a wider tire like a 305/25R19 Pirelli. I think Pirelli has one of the softest compounds among the 19" tires. Did you try lowering your tire pressure?
Flavio
I used to run Yokohama AVS Sports...I would recommend them to anyone. Pretty good combination of price/performance/longevity.
I had a Yoko AVS sport blow out on me on the highway. It just separated at the inner seam. They were fairly worn though, but I didn't have much love for these tires. I would say the SO3s kick their ass pretty good in all areas. Only MHO.
Adam
Discussion Starter #8
Flavio
Is that what size you use?
Does it ever rub?
I also want to get H&R spacers like you, where did you buy them?
Did they come with the studs?
Does it ever rub?
I currently have 275/30 but will have the 305/25 within a couple of weeks, I've waited for them for almost a year!
I don't think they will rub, but I'll know for sure when I've fitted them. I have my fenders worked a bit as well.
The H&R spacers came with the longer studs. Any shop that sells H&R springs should be able to get them.
Flavio
Discussion Starter #10
You do realize by going with a wider tire with more surface area it will remain cooler and probably have less traction than a 275.
Discussion Starter #11
Adam
Are those HRE's 19"?
I saw your pics, love your car.
It's my favorite one on this board.
Here's a pic of mine.
The hood scoop is now painted gunmetal (same color as the inside of my 97 head/tail lights).
And it now has a Stillen front soon to be painted.
BPU is so 1997
H&R doesn't make longer studs for the MKIV if I do recall.
If you have a source for them, please let me know.
Yes they are HRE 545 19s. Thanks very very much for the kind words. I am glad you painted the scoop, it is the only thing on the car I didn't like. Love the Dronel wheels. They look sweet. Try the SO3s, cheap and I don't think you'll be dissapointed. The 285/30/19s are what I have but check your offset to make sure they fit.
Adam
I love the SO-3 tire. The best tires out yet, and for 19 inch size the price was better than I though they would be.
T78supra -
You’re the only other Supra that I have seen that has the Dronell Type 1. When did you get them? Looks very nice! I also would like to know if you too had to roll the rear fender?
B
Where the fuck did you get that idea? Thats one of the stupidest things I've ever heard.....
100% Stock
Huh....wider tire=larger contact patch(being that they are same tire)=more traction. I don't know where you came up with the heat theory either....
Moderator
Given the weight of your car and the tire pressure remain constant, the surface area (foot print) will not increase or decrease. You are mearly changing the shape of the footprint to be wider and shorter. But you will not increase your straight line traction by going from a 285 to a 305. The cornering traction is another story :)
Later, Steve
Discussion Starter #19 (Edited)
This is a common tire fact.
Increasing tire width will decrease tire surface temperature because the load is spread out over more tire.
Everyone I have ever raced with whether it be Porsche Club of America, SCCA, or One lap of America has known this.
Bigger is not always better.
This is especially true with R1's
We would have to run 3 psi less in a 255 than a 245 just to keep the tires in operating temp (we would measure them with a temp gun after each warm up lap).
The lower pressure would make the tire a little unstable on fast straights so we would use the 245's on fast tracks (Lime Rock) unless the track temp was over 100 degrees then the 255's were OK.
Their are alot of variables.
Of course you may not have this problem, You can just adjust your roof scoop for more downforce right? lol
Discussion Starter #20
Are you saying that a cold tire has the same traction as warm tire?
Or that a wider tire will run as warm as a skinnier tire?
1 - 20 of 25 Posts
